Question for you out there that have run a 292 in a truck
waterpirate
delaware
v10
5.7 tbi
I stuffed a 292 into my m37. A popular conversion prior to the perkins 4BT option. It was unstoppable. In 4 low 1st gear you could get out and walk faster than the truck went.
Carb'ed Vortec 350
You may consider a 6 into 1 header instead of dual 3 into 1 headers, or have a merge and a large diameter single exhaust (like 3 inch or so), it helps with the scavenging and can help mileage a wee bit too. Keeps them quiet too, they get loud when split into duals.
Sent from my Moto Z (2) using Tapatalk
Curious why they get loud with dual threes, as opposed to single 6. I can see going dual three into single six. I'm talking cylinders, not pipe diameter. Going that route I could leave some of my existing 2.5 inch exhaust in place and have him run dual 2 inch into it.
I've never heard a dual exhaust inline 6, but I've read it's a distinct sound. May have to check out YouTube to see if there's any videos on it.
Carb'ed Vortec 350
Just watched a few videos of various 292 exhaust sounds. The duals sound mean. Raspy. I bet with the right setup it could sound good but not be too loud.
legopnuematic
Licensed Junk Dealer
MO
Spencer
I believe it is because of the firing order, on a Chevy six the front most cylinder is #1 and the rearmost is #6, going up in order, the firing order is 1-5-3-6-2-4 so when split up in 2 headers there is no cylinders that share a header that fire back to back, whereas with a common header/manifold there is always a pulse from the last fired cylinder, I'm sure the cam overlap has some part into it too with the lack of scavenging to muffle it or something
350 w/203
The 292 would be a great motor for the 65. We had a 70 two ton grain truck with a 292 and it was a torque monster. It would be refreshing to see that rather than a big block.
My grandfather had one of those and it was one tough beast for many, many years! Not bad on gas either.
Carb'ed Vortec 350
So ideally, a Doug Thorley tri-y style header would be best. Although, like you said, take the front 3/rear 3 dual into a single for better scavenging effect, that may be easier. I plan on doing the lump upgrade, HEI, and dual exhaust into single at the very least. The lump upgrade alone increases the torque a lot over stock. And that's why I got this engine, to have torque.
I also want an Offenhauser intake to run dual carbs, or an intake to run a q-jet. Simple upgrades that make the engine more efficient.
Going through my '63 shop manual right now, and these engines really appear to be easy to work on.
Compression is supposed to be 130. If that is all within 20 psi on each cylinder I may just check the main bearings and rod bearings, reseal it and run it.
Adjusting the valves is similar to the small block with hydraulic lifters, where you find zero lash and turn 1 turn past zero lash.
Carb'ed Vortec 350
I got some oil over the weekend and a new filter so I can get some fresh oil in it prior to turning it over. These engine's use the same filter as the 350. The spark plugs need a 13/16" socket.
Carb'ed Vortec 350
Does this look about right?
Carb'ed Vortec 350
Never mind, I got my answer. The way it is shown will work to turn over the engine on a stand.
Todd1960
