Question about vacuum line for Charcoal Canister
Iamthewalrus
Austin
Austin
I have just gotten my truck tuned and timed correctly, and I've noticed that there's a line just hanging open in there that I figured out is from the intake manifold to the charcoal canister, which is no longer present. When I fully plug the line I idle lower and sounds a bit better, but it doesn't continue to run right and eventually dies at idle, but is idling perfectly otherwise. What's my correct action for that line here? Should I just leave it open? How will this affect how it runs?
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
its an open vacuum leak sucking dirt into the engine. You have to plug it and adjust the carburetor or put a charcoal canister back in. Personally i would put the canister back.
The exact configuration of the canister changed over the years, but based on diagrams I've seen yours should have been controlled by a canister purge valve and a connection to the EGR valve. The design allowed it to draw vacuum and purge the crankcase under certain conditions, but then closed off the connection during most normal operation. This prevented having a constant vacuum leak.
wonone
