Question about center grilles - 81-87
mxer147
Colorado
Jack
k20
I’d be interested to see since I have a 82 grill I was considering installing, pics please.
Moderator
Yeah, me too. I haven't seen an uninstalled '81-'82 grille in a coon's age and can't remember the mounting difference.
C10_Blackie
Seattle, WA
Rob
It will physically fit, no problem, but 2 trim screws should not line up, unless the splash apron has been changed already, in which case, 2 screws should not have lined up on the 81-82 grille.
Believe I have at least one of each style, and can take photos for reference, if anyone is interested.
Yep - you are exactly right and I spoke too soon. The top secures nicely and the center screw on the bottom fits nicely, but there are two flanges on either side of the bottom are unsupported.
So you are saying that these attach to the splash guard and not the headlight bezels? Yes, I’d like to see photos if it is not too much trouble.
I’ll have to go back and see what a splash guard looks like and how much trouble that is going to be to source and replace. I may just let this one hang as is and then replace with a correct repro later - or maybe figure out a way to make brackets to secure them somehow. Thanks for posting.
C10_Blackie
Seattle, WA
Rob
BTW - before and after pics. To my eye it is a huge improvement.
Moderator
Could you not just drill a 1/8" hole and use a #8 trim screw to fasten? Or is there not enough flange there?
C10_Blackie
Seattle, WA
Rob
Ha. I had to to exactly that when the center flange snapped off, but no suitable place at the edges.
Maybe looking at it again after a good night’s sleep will shake something loose. I could probably make some supports out of stiff wire. It is very well secured at the top so it won’t need much - just enough to keep it in position.
C10_Blackie
Seattle, WA
Rob
Is this the component that the grille would mount to? (LMC calls it a “lower grille panel).
Moderator
Yeah, that's it. Although, I'd just find a used GM part. It will fit better and cost will be cheap. Should be very easy to find.
vr1967
Virgil
k1500
6.2L turbo
Give me a day or two as I haven’t been able to lay my hands on my 81-82 piece, but am still digging thru parts. If not, I know where one is I can get a hold of.
Have found several styles of t case cross members, so may photograph them denoting styles for reference purposes too
CheemsK1500
K1500
When I got my ‘85 it had one of those awful JC Whitney grilles on it. I was happy to ditch it. I don’t know why those were even ever remotely popular to begin with. They make the truck look like an air conditioning unit.
As for fitment, you can put an 83-84 or 85-87 grille on an 81-82 truck, you just end up with unused parking lamp mounts inside the grille, since parking lamps mount in the front bumper of an 81-82 truck. To this swap the other way around, you have to either include a 81-82 front bumper or modify an 81-82 grille to accept 83-84/85-87 parking lamps.
vr1967
Virgil
k1500
6.2L turbo
Have not been able to lay my hands on a true 81-82 piece. Hadn’t forgotten about it. Do know where a wrecked 81 is that I’m trying to catch up with the owner.
Jeremy89
