Quadrajet Filter Spring
Nottle
Saylorsburg
Guys does anyone know if a quadrajet on a 1980 K20 350m would have the fuel filter spring and if so anyone have a part number?
I grabbed a new filter today and when installing it I noticed it didnt have a spring, not sure if it was taken out or never there.
I have been poking around on the net and cant find an answer of if it should have one and the correct part number.
Thanks for the info inadvance,
Chris.
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
Radiohead
That guy on the Columbia
MCMLXXIX
C-20 Silverado Camper Special
IIRC (which is always in question these days) the short filter used a spring and the long one didn't. That's 60+ year old memory for ya.
Nottle
Saylorsburg
See this is the question I have. I keep getting different answers to if the long filter has a spring or not. My truck had the long filtter and no spring. So i will just leave it that way.
Nottle
Saylorsburg
HotWheelsBurban
Houston, Texas
Carol
R2500 Suburban
That's the way I remember it too. I'll have to ask my retired mechanic cousin next time I talk to him....
I also remember there being 2 different styles of the nut/filter housing that screw into the carb body. IIRC the Chevy/GMC carbs had the fuel line come in from the passenger side of the engine (up from the fuel pump) and most of them had the shorter nut and the short filter. Some had the long one, and there's also a brass "rock" filter(AC#GF455) that fits like the short one. May predate the square body carbs though, but has better filtration.
The Pontiac/Buick/Olds/Caddy carbs had the line come more from the front (different fuel pump location on some) and that straighter connection has the longer filter.
This is my recollection from the parts store in the 70s and 80s, and helping Dad with the QJs on our vehicles. Last time we had one apart was prolly 20 years ago....
Maybe it has already been mentioned, but the spring helps to hold the short filter in place, so it does its job. Whoever designed this was a genius, except for having to change the filter and get the nut threaded in properly, and then threading the fuel line in and not messing the whole thing up. What Dad did on our rigs was install the AC #GF62C auxiliary filter, that has a metal can that threads onto an aluminum adapter that bolts to the frame inline with the fuel line from the tank. Under the cab is a good place on a pickup, under the second row door on a Burb. This uses an AC # GF157 filter cartridge that's about the size of a soda can, and that way you don't have to mess with the little one very much. I think we got a year or more out of those cartridges, even driving every day.
GM got smart on the injected trucks, with an inline filter that's easy to access on the frame. Even has a bracket that holds it and the lines....
Radiohead
MCMLXXIX
The detail.... man that's exactly how I remember it too with the high end cars having filters that faced forwards and yes, the sintered filter elements in that kind of copper color. Aww man, those memory cells enjoyed the exercise, thanks. Lol
HotWheelsBurban
Houston, Texas
Carol
R2500 Suburban
We got the parts store right before I turned 11. I was a Daddy's girl anyway and loved cars. Yes I was playing with Hot Wheels and Matchbox cars! After we got the store, I was either there, or at home or school.....
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
Yeah I found that site off of Google as well, I just couldn't figure out if I need the spring or not.
Seeing that the long and short have springs in the pics, I'd say spring no matter what. I mean, how will the filter stay seated against the inlet if there is no spring to keep it seated against the inlet. Call quadrajet power, call Cliff Ruggles, call Lars, call any carburetor shop and ask them directly. That would be my recommendation. Or just get the spring...lol...
It should have a spring,a windowed needle and seat and fuel filter with a check valve. All the people smarter than the GM engineers are going to tell you throw away the check valve,but unless you have much higher than stock fuel requirements leave the valve in place. It can help with extended crank times on windowed needle and seat qjets.
Nottle
Saylorsburg
Thanks guys and girls. Ill pick a spring up and see if it all fits.
My little sister gave a boy a bloody nose as a little girl. I said something to her about it years latter she,said yea, I had you and Pat as brothers. She did everything we did LOL I don't know if that's a good thing or a bad thing.
HotWheelsBurban
Houston, Texas
Carol
R2500 Suburban
My best friend in third grade was an only child like me, but her dad was in the "oil bidness" so they were a bit better off than my family. She had every Barbie toy or accessory, but her folks were also enlightened enough that she had toy cars too. She gave me Matchbox and Hot Wheels cars for my birthday and Christmas, and I still have some of them over 45 years later.
They also had a travel trailer for their vacations, and a square body Burb with a 454 to tow it. Red and white, Silverado, with tan vinyl interior, 73,74 or 75, and I don't remember if it was a half ton or 3/4 ton
WesN
Edmonton Alberta Canada
Wes
C1500
Measure the bore in the carb and measure the fuel line nut depth where the filter goes and you can calculate how much room you have for a filter and spring.
Side note I have found that some filters that have the rubber check valve that they are made with way way smaller ports than the GM original ones had. Could be a problem depending on how you drive and or load.
Danger Dave
