Q jet choke has defected
bigcountry78
Hickory, North Carolina
James
K10 Custom Deluxe
That's a neat gizmo @Georgeb. A little outside of my fan skill set though. So did you have a manual pull knob inside the cab?
MadOgre
NA
NA
NA
NA
NA
First thing I would do is get a flat head screw driver and a shop vac and clean that mess up on top of your engine! Holy freaks I can barely see your engine let alone anything else!
Ya unless you can get that screw out, your looking at either a newer carb with electric choke or a new intake so you can remount the choke spring properly.
Georgeb
Wisconsin
George
K10 Burb Z71
Yes, I had the pull knob inside the cab mounted through a little bracket below the dash. I would put the pedel to the floor, pull it all the way, pump it one more time and start it. Then push it in about half way and let it warm up a bit. It took a little to get used to but prior to getting my 78 C10 with the same setup you have all I ever has was a manual choke pull.
bigcountry78
James
K10 Custom Deluxe
Heck that sounds like a better system anyway. I tried a better drill bit this morning, and I actually got some metal shavings out. But I didn't have much time to fiddle with it. Got my 04 sold today so I can focus on getting this truck in better shape. @MadOgre a clean motor is no fun to work on though.
bigcountry78
James
K10 Custom Deluxe
Finally got this fixed. I got a higher power drill and a good bit set and finally have a choke again after 10+ years. Now if anyone can tell me how to adjust the secondaries properly I'd appreciate it.
bigcountry78
James
K10 Custom Deluxe
Thank you for that link, I'll see if I can get some time to mess with it this week. I'm scared to do too much to it, the truck runs great and gets decent mileage all things considered, the secondaries just aren't working as far as I can tell. I def don't want to end up with it running poorly.
tkeefe
