Pto removal
farmerjeff
methuen
jeff
454 4 speed
I’m removing a 454 4 speed with a pto and putting in a 79 Chevy I want to permanently remove the pto is this something that can be done?
what is the PTO? Hydraulic pump?
Either way, you just unbolt it and put a cover over the opening...
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
If it was any good and you want it gone, I might want it.
farmerjeff
methuen
jeff
454 4 speed
Not sure it’s a 74 gmc dump truck
farmerjeff
methuen
jeff
454 4 speed
I get the truck delivered Monday or Tuesday depending on weather and when I yank it then I will see
farmerjeff
methuen
jeff
454 4 speed
Pto is removed by previous owner any way to identify the transmission by the #d
if your shift pattern is L in the upper left, 1 is down, 2 is up, 3 is down, and R is reverse to the right
or it says 1 in upper left
2 is down
3 is up
4 is down
and r is down on the right (same pattern but all numbers no L)
and your transmission is what the PTO was on, then its probably an SM465
your case crosses to a SM465 the # on it. 6273212
Mudbeast2
