Problem Finding Correct Kickdown Detent Cable TH350
Hack Richards
East Kentucky
Richard
K1500
350cc
1982 GMC TH350 hooked to Edelbrock Carb/ 350 Engine
My kick-down cable must be a bastard because I have ordered two from the internet and both were too large to fit in the transmission. My old one is 25/64" (9.93 mm) in diameter without the seal/o-ring. The other end does not matter...I'll fashion something that works to my Edelbrock.
No one has one locally and online - one cannot tell from photos what they are exactly and no one gives that particular specification/ measurement.
Can anyone help me find one OR the correct part number?
Thank you Kindly in advance!
78C10BigTen
pennsylvannia
C10 BIG TEN
I think i had one or two extra cables but god knows what i did wit em
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
I think all kickdown cables measure the same, they use a o-ring. The later THROTTLE VALVE (TV) cables for the overdrive trans use a boot type seal. Are the parts store trying to sell you a TV cable and not a kickdown for 350?
Hack Richards
East Kentucky
Richard
K1500
350cc
All I know is that the 2 that I have purchased already and returned were BOTH for a TH 350 and BOTH had difference size fittings. Both were too large. The first one was not even the correct shape and was huge. The second one looked like my original BUT was about 7/16" in diameter. The one I need is 25/64". Like I said I have a Basterd.
Hack Richards
East Kentucky
Richard
K1500
350cc
https://transend.us/search/catalog/guided?pageNumber=1&transmissionId=134&listType=1&year=1982&description=detent cable&vhid=f199ea5294f033a0&searchType=catalogGuided&priceDisplay=false
Found 3 different styles for 2 different hole sizes. I need the .458 size so Now I am good. I can get this from Ebay.
  • You must be registered for see images attach
    Detent Cable, 39" Outer Conduit, 44" Wire w/ Metal Carburetor Slide (.458" Diameter Hole in Transmission)
    Teckpak
    T44450
    THM350
    1969 - 1986
    Item Price:
    $29.06
    Detent Cable, 34.5" Outer Conduit, 41" Wire w/ Plastic Teardrop (.690" Diameter Hole in Transmission)
    Teckpak
    T44450A
    THM350
    1969 - 1986
    Item Price:
    $21.92
    Detent Cable, 23" to 39" Outer Conduit, 48" Wire (Universal 350 Style)
    Aftermarket
    44450U
    THM350
    1969 - 1986
    Item Price:
    $29.29
86sunnyguy
