Power windows and locks don't work
Darth Plasma
Pennsylvania
Nathan
350/SM465
I recently rewired my truck after doing a cab swap, and I finally got everything hooked up and working. The truck has power windows and locks but they don't seem to work right. The driver's door does absolutely nothing. The lock and window doesnt work, but the switches trigger the passenger's side. The passenger's side lock works when hitting the switch but when trying to use the window it only goes up. Same thing when using the passenger's switches. Keep in mind this problem occured before I tore apart the truck and rewired it. I just replaced the connector for the driver's dual window switch because the wires were fraying and a couple were broken off. Any help?
gmachinz
Harnessworx Inc
Iowa
Jabin
Most likely broken/melted wiring inside the cab-door boots...common problem with old, OE acrylic jacketed wiring.
Darth Plasma
Pennsylvania
Nathan
350/SM465
I'll take a look at the full wiring and see if I notice anything obvious
Snoots
Roger
Jimmy Sierra
350 w/203
Switches control the +.
Check for a good ground at your doors too. Just because they're 'connected' through the hinges don't mean diddly.
gmachinz
Harnessworx Inc
Iowa
Jabin
That doesn’t apply to 1982-up trucks. The common bussbar ground for the window circuit is under/behind the dash. 1977-81 window motors were however, self grounding.
Darth Plasma
Pennsylvania
Nathan
350/SM465
I got the driver’s side working after fiddling with the plugs and switches and cleaning them, the passenger’s switch doesn’t work because it’s broken, but works fine being controlled from the driver’s side. Gotta get a new connector and switch
twzorek
