Blue Ox
Turning Diesel Fuel Into Fun
- Mar 27, 2018
- LI-NY
- Derek
- MCMLXXXV
- K20HD
- 6.2L
I've known Furd Hydroboost systems fail because people used ATF in them.
I've known my hydroboost system to fail from using ATF.
Factory install was ATF and the hydroboost leaked into the cab. Replaced the hydroboost and it failed again. Third one got PS fluid and it's still in the truck 30+ years later.
BTW, the manual specifies Dexron. No mention of PS fluid.
If I had the option I would use PS fluid. But if the system already has ATF in it, and most of them do, I wouldn't mix and match.
On a side note, my carpet and backing is now thoroughly soaked in oil, which may have something to do with why I still have a floor.
