Power door locks not working?
Bman
Oliver springs,tn
Ben
GMC sierra classic 1500
5.0/ 305 LE9
My 83 sierra classic has power windows and locks.
Driver window works. passenger im sure the motor is shot/ switch is unhooked.
I was wondering why my door locks didnt work at all. neither door. neither switch. no noises or anything.
whats the likely hood that both actuators are shot? or is it more simple such as a lack of power to the actuators? if so what should i check?
Boone83K10
Boone, NC
Benjamin
The power window and door locks are separate circuits but run on the same loom. The door locks could be a couple of things.
1. The easiest is to get new switches. I did this and my LOCK feature worked again. They are flimsy on the inside and contacts wear out in them.
2. It could be the relay that is used in the lock system. They are hard to find under the dash, and hard to find at the parts store.
3. Window could be motor or power to motor... or maybe even the switch.
Wiring Diagram for you...
Boone83K10
Boone, NC
Benjamin
Bman
Oliver springs,tn
Ben
5.0/ 305 LE9
Thanks ill have to get out there tomorrow and see. can i test if it my switch without buying a new one?
and that motor when i hook the switch back the motor clicks and maybe moves a cm.
chengny
There should be power available at the jack indicated (E) in the dwg below. And there should be an orange wire plugged into that jack. The orange wire is the hot lead to the power lock system.
Bman
Oliver springs,tn
Ben
5.0/ 305 LE9
okay so i went out today and played around with it. they are getting power. everything is good up to the switches.
and so my test there was to jump the power wire (orange and black) to the others. if i went to the blue wire the the locks would lock. but if jumped to the black and white (unassumingly unlock?) wire nothing would happen.
so i thought 1 well switches are bad for sure. so i took them off and opend and cleaned the contacts. they both will work to lock the truck. but not unlock?
And i tried the jumping wires on both doors. locking was fine. but neither would unlock.
any ideas as to why?
chengny
There's no "neutral" position- you know what I mean. The plunger is either up or down.
So, if they can move to the lock position - they were previously in the unlocked position (or trying to get there).
If the buttons don't go down, it's probably a mechanical/linkage issue, not electrical.
Bman
Oliver springs,tn
Ben
5.0/ 305 LE9
from my understanding(after seeing the inside of the switch) the switch diverts power one way or the other. either to make the actuator pull or push the lock.
Now what i dont understand is why even jumping to the wire does nothing.
edit: Okay so i went out and took a test light to that side of the switch. and its sending power both ways. so im going to pull the panels and look and see the wiring. and to clarify what they do. the switched are able to move the buttons and locks into lock from unlock. but wont unlock at all. nothing happens
Boone83K10
Boone, NC
Benjamin
My truck would lock, but not unlock. Switches were bad. Replace yours, its cheap.
Bman
Oliver springs,tn
Ben
5.0/ 305 LE9
well the switches work. according to the test light. ill have to check the wiring
Boone83K10
Boone, NC
Benjamin
So did mine, but a test light is misleading. I wasnt getting but around 5v. Enough to light a test light, not enough to energize a lock actuator. A multimeter would be best as I found out.
dob555
