Possible? Worth It?
GOBR
Memphis
R10
Next time I pull the engine I want it to be easier to do. Maybe even pull the trans out with it. Basically I want to remove the radiator support and radiator...... I can see its spot welded but theres also bolts. Could I drill out the spot welds and remove it and bolt it back in? I dont see why not and has anyone done this before?
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
The radiator support unbolts from the frame, fenders and fenderwells, no drilling required. It may actually be easier to unbolt the fenders from the cab, and unbolt the radiator support from the frame, unhook everything that needs unhooked, close the hood and lift the whole she-bang off at once. This will give you room to fiddle with the exhaust, plugs, motor mounts, etc. Of course this depends on how your hood hinges are mounted, I've only delt with pre-85.
GOBR
Memphis
R10
Mine go into the cab of the truck. I could still unbolt the fenders and everything else and take that off as one piece. I didnt know it all came off cause it looks like its all connected up front. Guess Ill have to look closer.
