Posi lock clearance
BBCfan
Edinboro
C10 2WD
I removed the 2" body lift and had to replace the valve covers for firewall clearance. I have posi lock rocker nuts installed. Now my clearance issue is between the valve cover and posi locks. Got my playdoh at the ready and have no clue what an acceptable amount of clearance should be in there. With a stock cork gasket they're very close to touching so I bought steel reinforced double thick cork gaskets. TIA, Rick.
Nborden88
