PNW Overland suburban WA
CookieSoup
Seattle area
Suburban
New to this forum and ill try and keep this updated as the build continues.
Living in the seattle area (not in the city to many people) started overlanding a bit in my 2016 jeep 4 door but i keep wanting something more dedicated/less worried about body damage.
So the time for the goods.....
The goal - Super simple - less things to go wrong - slow and overbuilt - mild cost to operate (tires/fuel/build)
The canidate
1987 GMC 3/4 Ton Burban
6.2 Detroit Diesel
TH400
NP208
Heavy tow package
G80 locker
Quad front shocks
10 Bolt front axle
14 Bolt SF rear
Hydroboost brakes
Step 1
TH400 is slipping BADLY so SM465 time
SM465 with long 32 spline output and NP208 adapter. and all the manual swap parts (pedals,z bar,linkage) Free from a friend
Ill reuse the 208 and drive shafts in the truck right now to same some cost and get some more miles on the motor before step 2
Step 2
NP208 to NP205 Swap - need to get the tranfur case input swapped to 32 spline, and the spacer for the adaptor since this SM465/205 combo is 10 spline (gross) and then twin stick
Came with a fully rebuilt front drive shaft and a rear two piece shaft (need ujoints and carrier bearing)
Step 3,4,5 ........ (once i get some miles on it)
35's
4 inch rough country lift
rear shackle flip
Ham Radio
CB - out of the jeep
Ipad with Satellite GPS
Bumpers
Winch - Warn 12k off the jeep
light bars
on board water tank
If you have any manual conversion questions or need something measured let me know.
She might end up this color - with a white roof
:welcome:
77 K20
Montana
K20 5" lift
HT383 fuel injected
Sounds like a great project.
You might want to look at Tuff Country instead for your front lift- it will ride softer/nicer.
Welcome!
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
CookieSoup
Seattle area
Suburban
well she is running and driving now. had to pull the trans 4 times but figured it out finally. got used lift kit for 100 bucks so couldn't turn that down. 35's are ordered and picking up some more H2 wheels tomarrow. and hopfully a serpintine kit too
77 K20
Montana
K20 5" lift
HT383 fuel injected
Sounds good! Post some pics when you get the chance.
CookieSoup
Seattle area
Suburban
I will when the tires come in for sure
77 K20
Montana
K20 5" lift
HT383 fuel injected
What kind of tires are you getting?
TravisB
Kentucky
Travis
:welcome:
Catbox
Peter
C20 Silverado Camper Special
Welcome to the page.
Sounds like a fun and entertaining project.
dvdswan
Port Orchard, WA
Dave
Welcome to the site from the other side of the sound.
BGPick
Illinois
C20 2WD
6.2L Detroit Diesel
Welcome!! :welcome:
CookieSoup
Seattle area
Suburban
treadwrights i had them on my last 2 trucks and they were great 600 bucks for 4 tires shipped. next year or so i might do 37's or 40's we will see how bad i hit this year with such a long wheel base
1973c10
Don
Welcome
