pics of 4.6/6 drop needed
bobster79
tx
bobby
silverado c10
I have a 84 Chevy Silverado that is 100 percent stock. i want to drop it just can't decide on 2.5/4 drop or 4.5/6 drop. i will be running P275/60/15 tires on truck. Any pics would be of help. Thanks and have a great day. :cheers:
J Knight
Baytown TX
82 Chevy
350ci
2/3.5
4.5/5
4.5/6
bobster79
tx
bobby
silverado c10
J Knight do you think i can run P275/60/15 tires with the 4.5/6 drop. Thanks for posting pics.
J Knight
Baytown TX
82 Chevy
350ci
You would probably be better off with a 3.5/5 drop running 275/60/15 tires on the front.
bobster79
tx
bobby
silverado c10
What size tires are on the white one J? Also thank you for your input on the subject.
Lugnut
Northwest Georgia
Jason
'79) 350/ granny 4-speed, '86) 350/A833 3-speed with overdrive
I have a 4.5 / 5 drop with 275/60/15 on 8" wheels all the way around.
I have no problems rubbing. I do take it slow turning into a couple places that has a big dip, but most fo the time every thing is fine.
bobster79
tx
bobby
silverado c10
on your 4.5/5 drop Lugnut what kit did you go with or how did you achieve your drop. Do you think i can get away with running the P275/60/16 tires all way around with 4.5/6 drop. Sorry so dumbfounded just want to do mine right the first time. Thanks
Lugnut
Northwest Georgia
Jason
Spindles and springs up front and axle flip in the rear. I had a weak leaf spring in the rear so I had my rear springs re-arched and a leaf added at a local shop. That added about an inch so it ended up with a 5" drop in the rear.
I didn't buy a kit just used parts that I had for some old projects that never got used.
As far as the 275/60/16 I'm not sure compare the OD difference between the 15's and 16's.
bobster79
tx
bobby
silverado c10
sorry meant 15's
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Mine....with 20×8 up front and 20x10 in the rear. First pic is before body work and final paint...second pic after body work and paint. 4.5 front...6 back
Spindles and springs up front, c-notch, axle flip , drop shackles and overload springs removed from the rear. I did have to remove the stock fenderwells and fab my own due to the offset of the front wheels.
Lugnut
Northwest Georgia
Jason
Looks great. I love the style of wheels on it.
My son has been trying to talk in to 20's and I like the way they look, but I'm still a little to old school I guess.
bluex
Spartanburg SC
C15
2.5 spindles one coil cut up front. Flip kit in the back, no notch. 235/55/17 on 8 wide front 275/60/17 on 9.5 wide rear.
bluex
Spartanburg SC
C15
I think a 17 is a good compromise but my opinion could be biased. I like the size on my truck, I'm working on air ride though an I might change to 20s then if I ever have the money to
Lugnut
Northwest Georgia
Jason
I like it. I have been thinking of running staggered 17's /18's on it. I like a little hot rod rake to
Scrambler-Cafe
