Parting out 85 K20
Status
Not open for further replies.
oneluckypops
Sedalia, Mo.
Luke
Dont know if there is anything on this truck that would be usefull to any of you all or not, But I will try listing some things. I am not planning on keeping the truck or any of the parts for very Long, so what ever doesnt sell goes across the scales with the rest of the truck sometime afternext week.
The person I bought the truck fropm said that it has a Crate motor in it with around 10-15000 miles on it. I have no idea if he is referring to it as a GM Crate motor or a jasper type engine. But at any rate heres what I know I am trying to sell.
350 Eninge (Low Mileage) 500.00
SM465 Transmission 200.00
Bellhousing (Hydaulic cluch) 50.00
NP208 Transfercase with shifter 100.00
Clucth Pedal Assembly with Linkage 50.00
Hydraulic Clutch setup
Slave cylinder, Resovoir, hose's 50.00
Front Driveshaft 25.00
W- Crossmember IF ITS USEABLE 100.00
NON tilt columb with dimmerswitch 75.00
Instument cluster (Idiot lights) 10.00
Wiring Harness upon request
single headlight set up 20.00
I will also offer these parts as a complete 4spd conversion for a cheaper price. I will include the following in the Kit:
SM465 Transmission
Bellhousing
Hydraulic Cluch Components
Pedal Assembly
Front Driveshaft
Steering Columb
Flywheel
Clutch, Pressure plate, Throw out bearing
W- Cross member
NP208 Transfercase and shifter
all bolts and harware that I take off I will include.
LOW PRICE of $400.00 obo
If you would like to have the NP205 Instead I can also sell that set up for an additional 100.00
There are no usable body panels
Pics certainly help joooknow !!! I could sure go for a Non automatic steering column even if I don't go with the manual. At least one of my truck is gonna have a B&M ratchet shifter.
I think I"ve let you talk me into that hydro clutch with the SM465/205. And of course I"d need the clutch pedal set up and may as well get the brake pedal too since mine is wider. WTH, just might be easier to find me a manual trans truck. :shrug: Damn, I have to many ideas, to many trucks and .... **** !!!!
I'd be interested in the bellhousing and fork, pending shipping cost. Could you guestimate to 43140?
oneluckypops
Sedalia, Mo.
Luke
ide guess it would be around 30 bux to ship it, course that could be way off depending if its a Cast bellhousing or an aluminuim one. My zipcode is 65340 if you can find anything else out.
ricks2500gmc
lincoln park michigan
rick
parts
Does this truck have a red interior? looking for complete headliner trim....
oneluckypops
Sedalia, Mo.
Luke
dont think there is any trim, didnt really pay attention though I will look and let you know for sure tommorow.
Should be aluminum. I'll guess it probably weighs the same as a mechanical bell, which I do have. I'll see if I can figure it out tomorrow evening and let you know.
I am farily certain the hydro clutch belhousnig is alluminum. And come to think of it, I do beleive I have happen to have one too. It came with that SM465 that I bought from a guy for $50 that converted to NV4500. I sold the trans for $50, but kept the bellhousing, clutch parts, and clutch fork. Maybe its not hydro though sicne I know it doesn't have the slave cylinder mounted in it, but he may have used the slave in the NV4500 set up. At any rate, point is, I'm alsmot positive its an alluminum bellhousing.
Illuminati
C
K10/Silverado
350 4bbl
If it does have interior trim let me know too. I'm looking for the pull straps for the doors...specifically if they're grey, black, or white. Thanks
oneluckypops
Sedalia, Mo.
Luke
sorry no doors on the truck when i bought it.
smurph20
Clyde, Arkansas 72717
Brad
350/SM465/NP208/4.10's
Carbed correct? What condition and what kind and how much to 72744?
smurph20
Brad
Bummer mine starting squirting gas out of the accelartor pump and runnin like CRAP lol. I have an Edlebrock intake for it not sure if i should rebuild the Q-Jet or stick the intake on it and run a Holley
Carb is already gone
Ahh fugg that. I hope to hell you you at least took a battery to see to see of the motor cranked, or grabbed the balancer and made sure the motor turned over. Taking the carb off and have it sit for how long??? Just for gp, I'd be pouring a ltitle diesel down the intke in all direction of the runners. Let it sit a bit. You need fo find a carb and get it fired up. Noone in their right mind is gonna give you $500 for a motor they don't get to hear run, and at least see an oil pressure guage. :shitsweak:
one low c10
Toledo,Ohio
Geoff
do you have the brackets that hold the gas tank? (not the straps) and how much if you do. shipping would be to 43612...thanks!
Status
PushyQueffer
