Part #s for ring&pinion and limited slip
bigtalljohn13
Illinois
V20 Suburban
350ci
Its late and im tired, i have spent countless hours the past few days reading pretty much everything on this site and others trying to come up with the best set up for my suburban. So far i have figured out that my rear end is a 14 bolt sf 9.5" with 3.73 gears (GT4 on the RPO sticker thanks to Retros thread a while back). The front is a 10 bolt and I don know the ring size. The motor going into it eventually is going to be a rebuilt 454 with 540-600HP and close to equal torque. I will have the TH400 rebuilt with a kit from Monster Transmission, and will more than likely buy a rebuilt NP208 from them as well. I will be running 37' tires. It wont be an off-road truck (at least not much and nothing extreme) but more off a dd and show truck. Im thinking i should go to 4.11 or 4.56 gears, and i would like to have limited slip in the front and rear. Any part #'s and suppliers will be much appreciated, Thanks in advance.
Oh and while im thinking about it (again) should i go with the 4L80E instead of the TH400. i have been leaning away from it cuz i haven't found a definite answer if my NP208 will bolt up to it. I guess i could call Monster Transmission and find out or see if i bought both from them if the could do whats necessary to make them bolt up. Thanks again.
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
Putting a limited slip in the front diff is going to cost you $500-$1000, and when you're done you will still have a 10 bolt with stock axles attached to 550 hp and 37" tires. Doesn't seem like money well spent. I got the "dd and show truck" part, so if you don't plan on romping in 4wd why bother with a limited slip in the front? I would either drive it the way it is, and if it blows up you haven't wasted a bunch of money, or start looking for a front Dana 60.
Anyhoo, here's some options for the 8.5" 10 bolt if you decide to go ahead with it. http://www.ringpinion.com/DiffWizard.aspx
Driver4r
Nebraska
Trevor
k10,c20
IMO, 550-600 horse is way overkill for a DD, my 375hp 355 roasts tires and i get 6mpg, Im guessing that 600hp will get 4mpg.
bigtalljohn13
Illinois
V20 Suburban
350ci
i guess a should have said an occasional driver. i want the limited slip front and rear for the snow, where i live the roads are on the end of the list for removal and my parents live down a gravel road out in the country and they have bad drifting out there. so i figured it wouldn't hurt to have it.
boarder421
