One headlights works when high beams are on
77Stepside_
Sacramento, Ca
Enrique
Bought the truck 2 weeks ago. Noticed only one headlight works when on high beams. A friend had the same problem, he replaced the headlights and problem solved. So I did the same, didn't solve the problem. What could the problem be?
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
Sometimes the pigtail will get corroded, they sell replacements on LMC. If it's the passenger side light there is likely a break or pinch in the wire between the driver side and passenger side harness, since the passenger side feeds from the driver side.
Camar068
Kentucky
10 yrs Air Force
Might be the connector for that bulb being loose. It could be a quick fix (I need to try it on mine). Add some solder to the connection on the bulb itself to make it thicker. Otherwise most parts stores have the connector.
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Bad connector, sometimes corroded at plug. Clean and use dielectric grease.
nathan27
