Oil Pan ID
Magna86
VA Beach
Magna86
Chevy 350
Looking to see if anyone can ID this as a truck or car oil pan? All I know is they are from crate motors and for a 1 piece block. The one on my core engine is dented and I can grab one of these cheap if it will work for a truck.
Supporting Member Army
It's hard to tell from the pictures, but the black one has an extra port you likely aren't going to need. Either for an oil level sensor or a temp gauge(or maybe a turbo return line). The other two look just like my truck pan. The car pans that wouldn't work are usually a front or middle sump. It's not clear to me from your post whether you have a 1-piece rear main or not? If those pans are from a 1-piece rear main seal crate engine and you don't have an engine block made after 1986-87 in your truck... none of them will fit your truck.
Magna86
VA Beach
Magna86
Chevy 350
I have a 90's TBI core engine so these will work. Thanks now to grab one of them.
Moderator
The crate engine pans tend to fit most vehicles that came with a small block originally.
nixon22
