Casey Rayls
- May 20, 2025
- Rising Sun, IN
- Casey
- K10
1982 Long Bed K10 4x4. I've installed TWO new printed circuit boards from LMC. (I assumed one board was bad)
All twist in sockets/lamps work alone (out of the dash cluster) they check good and will light with direct 12 volts from a battery.
Only the bright/dim lamp will work on the dash cluster (see pic). No other lights work, but all have working bulbs and strong ears to make contact with the P/C board.
The old, ratty printed circuit board worked fine before !
Head lights go out completely when floor dimmer is depressed. Come back on when dimmer is pressed again. Replaced dimmer switch and same issue, so not the dimmer switch, guru.
Now, last night, the head lights started blinking slowly when driving !
When I turn the headlights off and back on, and they will work as normal again for a few more minutes before going to a slow blink again.
Taillights and turn signals all work, but won't blink in the cluster, though I can hear them blinking.
Interior under dash and over head lights work as normal.
