shovelbill80
- Apr 17, 2026
- NY
- Bill
- GMC Jimmy
The most usual culprit is the bulb shorting in the socket... try to take the bulbs out (they may be 'fused' in)and look into the socket if you can. The 1157 bulb has 2 filaments, and the socket has the corresponding spring-loaded contacts. I'll wager the thing is all sorts of gunked up with grease, corrosion, and whatever else fell in there over time...So as it turns out, don’t use AI for a wiring diagram. I was checking the wrong fuse. Found the correct taillight fuse and it was and still keeps blowing when I turn on the lights. Obviously I am not an electrical guy so what might cause the fuse to keep blowing immediately after replacing the fuse and turning on the headlights?
Check the reverse lights, too. That should be a single filament 1156 bulb.
