mcarlo86
- May 17, 2019
- ND
- Brian
- Suburban
Well, I am finally getting around to putting the NP833 in my '68 C10. I never did like the wonky shifter set-up that came with the transmission, so I kept looking for another shifter and one finally did show up on flea bay a while back, so I grabbed it. You can see the shifter that came with my transmission has some homemade bracketree on it to space it out and then they made an off-set adapter to put the shift lever in the right spot. Combine that with the heavily modified shift arms, and it just made me nervous. After comparing the correct shifter with what came on the transmission, I'm pretty sure somebody modified a regular Hurst 4 speed shifter for like a M22 to work on the NP833.
