No reverse lights, no power to bulbs
Corpse
Toronto, Canada
Ramon
K5 Blazer
6.2 Diesel
I have no wiring diagrams, anyone know if there is a common issue i should check first? My fuse panel has worn out labeling on it so Im unsure of what should be there...
Thanks
Sent from my GT-I9100M using Tapatalk 2
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
If automatic check the switch on the column, if standard check the switch on the trans.
J Knight
Baytown TX
82 Chevy
350ci
If switches are good check wires along the drivers side frame rail.
Corpse
Toronto, Canada
Ramon
K5 Blazer
6.2 Diesel
Auto. Where would i find the switch on the column?
crazy4offroad
Curt
K-10
350/SM465/NP205
I think it's down near the main connector on the column. I believe it uses a purple wire and a green wire.
Corpse
Toronto, Canada
Ramon
K5 Blazer
6.2 Diesel
Awesome. Thanks. Fixed it, loose connection at the switch so i replaced the connectors
tnahaus
