No power up hill or after 45 MPH
78 Square
Pennsylvania
Justin
Should something be touching where that spring is?
78 Square
Pennsylvania
Justin
Sorry guys, I'm not sure why they're all sideways.
chengny
Indexed correctly and twice as big:
MadOgre
NA
NA
NA
NA
NA
Thanks Jerry
I would say for starters get a couple cans of carb cleaner and spray all the linkages down real good while trying to move the throttle back and forth.
I would also check and make sure that the Secondary Throttle -Blade Lockout tab is allowing the secondaries to open. You need to check with the engine fully warmed. Its a little tab on the passenger side that locks the rear secondary throttle shaft from rotating until the engine is warm.
I circled it in red
grandpa's75
Montana
I just came into a 75 K20 with a 292 i6, 4 speed manual. Went to bring it home and had the same issue. Starts fine, idles fine. 1st, 2nd, gear no problems. Getting up to speed in 3rd and more so in 4th, it's like she chokes out and starts sputtering. I was thinking carb issue. It has a Rochester mono jet. Anyone have thoughts there?
MadOgre
NA
NA
NA
NA
NA
Is it RPM related sounds like maybe it is a clogged fuel filter or mechanical fuel pump on the way out.
grandpa's75
Montana
I don't mean to take away from what you got going 78 square. Similar issue, hoping to get some help too.
grandpa's75
Montana
I can pop it out of gear, rev the engine and it comes out of it. Back in gear and right back to sputtering.
MadOgre
NA
NA
NA
NA
NA
Start a help thread and add all the descriptive details that you can and we will help you out in your help thread. :)
mick84
