Doubletop
- May 25, 2020
- Muncie, IN
- Doug
- Sierra 1500
At my wits end. 1987 1500 305 TBI engine. A few months ago, the ICM went bad. I screwed up and broke the connector inside the distributor so I ended up replacing the whole distributor. The problem the truck is having now is that it runs great speeds in town, but I've lost all power at highway speeds and fuel mileage has dropped from 12mpg down to 8.
So far to try and find the problem the following items have been replaced.
- Distributor (Changed it twice since problem appeared after initial change. Bought top of the line from Summit)
- Rebuilt throttle body
- A/C Delco new fuel injectors
- Fuel filter
- O2 sensor
- Knock sensor
- MAP
- TPS
- EGR Valve
- EGR Solenoid
- Plugs, wires, and coil
- Catalytic converter and muffler
- Coolant temp sensor
EGR valve and solenoid are now testing good. Vacuum reading at idle is a solid 19 with no movement at the needle during idle. I've also sprayed cleaner around throttle body and vacuum connections and not finding any leaks. Timing set at 0 with wire unplugged. Good fuel pressure before fuel filter. Compression is good, but have not down leak down test. I've cleaned and redone the ground wires at thermostat housing. No codes are being thrown. It's not missing out. Fuel injectors good cone spray pattern. I don't have smell anymore so I can't tell if I have a fuel odor at exhaust.
Couple things I noticed. Cruise control stopped holding speed at the same time. It still engages, but will slowly lose speed. I took apart the cruise solenoid and rebuilt that according to a video I found online. I also noticed today that when I had blower motor on vent (no A/C) the fan would slow down and nearly stop at higher rpms. I know that's normal on some newer vehicles to help with power, but wasn't sure if that was normal for this year of truck.
Any ideas would be greatly appreciated cause I hate taking my stuff to be worked on by someone else.
- Fuel filter
- O2 sensor
- Knock sensor
- MAP
- TPS
- EGR Valve
- EGR Solenoid
