Newbie: Idles rough, stalls when put into gear!
CTread08
Nicholasville, KY
Corey
When I inspect the distributor cap/rotor should I automatically replace both or look for cracks, looseness, corrosion, etc?
87scotty
Central il
Andrew
V20
5.7 for now
If its caroded replace if clean its probably fine! But I'm guessing there will be some buildup
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
Yup, ignore the ridiculous underhood sticker. If you happen to get pinging with 12 degrees, back it off a couple or just run a higher octane fuel.
FWIW, the guy's over at GMT400 (my DD is a 95 GMC TBI), swear up and down that anything more than the factory 0 degrees causes knocking.
Kinda blew my mind, I've never seen a motor that didn't enjoy some timing.
TO the OP, I'm going to say that your truck is probably just due for a tune up. It could also be running very rich, have you had a plug out to look at it?
Yes, check the cap. And make sure it has brass terminals, those brass part's store thing's are junk.
Georgeb
Wisconsin
George
K10 Burb Z71
The esc plug is right here between the steering column and the bulkhead connector through the firewall.
Georgeb
Wisconsin
George
K10 Burb Z71
Mine ran freaking great at 12 deg
CTread08
Nicholasville, KY
Corey
Ok I'll check the cap. And do the tune up. If the cap or rotor probes to be bad, where should I buy a replacement since you said the parts store replacements are junk
CTread08
Nicholasville, KY
Corey
And no I haven't had a plug out yet, but that is the plan for the weekend to replace plugs. If it's running rich they'll be black right? And I was told to use ACDelco plugs as that's what came from the factory?
Georgeb
Wisconsin
George
K10 Burb Z71
I have had good luck with the standard brand caps that have brass terminals. IMHO I believe they work better and stand up to the ozone corrosion that occurs inside the cap. But If your in doubt go with AC Delco parts.
Georgeb
Wisconsin
George
K10 Burb Z71
I would still spend some time checking for vacuume leakes and also checking on the egr valve. Your symptoms sound more like they pertain to that. I have seen some really bad ignition parts still run fairly well.
Jrgunn5150
Ionia Mi
J.R.
6.slow
Sorry, I didn't mean not to get one from the store, just make sure it has the brass terminals, not the aluminum ones, they are the ones that suck.
Correct, black is rich, you may also notice some black smoke out the tail pipe. ACdelco's work fine for me, I use R45's in my small blocks, gap them yourself.
CTread08
Nicholasville, KY
Corey
Ok I'll do some looking over that too. Is there a place on this forum to see the vacuum lines and their proper destinations/routes/etc. thinking about it now, there is a canister on the driver side, in front of the wheel well and behind the radiator that has two black tubes on the top, one of which is simply laying on top of the wheel well. If I can be pointed in the direction of a list or pictures or something showing the vacuum lines then I can go over all of them and rule that out.
Georgeb
Wisconsin
George
K10 Burb Z71
Here is some EGR info.
http://troubleshootmyvehicle.com/gm/4.3L-5.0L-5.7L/stuck-open-egr-valve-tests-1
Joestreml
