Frankenchevy
Proverbs 16:18
- Jan 3, 2018
- USA
- Jeremy
- Square
- CUCV
- Small
I slid my torque converter out of my transmission to clean the inside of the bell housing. The truck is on a very slight downhill and the transmission may have also been pointing even more downhill as it is currently being held up by a ratchet strap. A small Dribble of transmission fluid came from around the shaft where the torque converter slides on, but subsided after giving the ratchet strap a few clicks to get it pointed back uphill. I imagine this is normal to fill the tc with fluid, but I just wanted to make sure.
I am happy with the way this torque converter feels for lack of a better term, but I was curious if anyone could identify it and might possibly know what stall it may be. It has a sticker with an M on the transmission side and also a sticker on the flexplate side that says 4M and then in a smaller portion of the front sticker the numbers 8655 017. All the way around the perimeter it has a stamping of ‘D 4’ and as you can see from the pictures, it is a 6 bolt converter.
Thanks in advance!
Thanks in advance!
