New fuel gauge not working
White_Lightning
Ontario, Canada
C2500
I’ve had problems with my fuel gauge constantly moving all over the place and sticking for a while, usually have to tap the gauge to get it to read correct. I have a new sending unit and went through the wiring to make sure everything was good and it was, made no difference. I’m assuming the gauge itself is the problem. I got a new gauge from LMC and just swapped the old one out and now I get no reading at all. Any suggestions?
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Bad new gauge ? Not plugged in fully ? Wiring harness to the cluster not plugged in all the way ?
If you get lucky, one of the latter 2 ...
Oh, what happens if you put the old gauge back in now ?
Good luck !
Britt
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Is the gauge grounded correctly? If you look on the back of the gauge and the thin circuit board there's usually a clearly marked - and +
Make sure somehow the one you got isn't backwards.
Is it pegged ?
Pegged full is a short on power side, pegged empty is a short on the ground side.
(I might have that backwards)
Thirdly, if its not pegged and just rests on Empty and the old one didn't work/got stuck, when you had the tank out, was there enough in there to register the float now?
And is the unit itself grounded? To the frame nearby?
wlwarnke
Helotes, TX
William
I believe the sensor is 0-90ohms (to ground)
0 ohms or shorted to ground reads empty.
90 ohms full
Open wire, sender ground wire bad read pegged full.
Have an ohm meter? Most trucks that I have seen had 2 sensor wires (just incase it had 2 tanks) connected to the gauge cluster. Measure those wires to ground. Should read between 0 and 90 ohms and be stable (if tank isn’t sloshing).
I have had the “spare wire” get shorted somewhere and cause issues. Just cut it off and leave the one that’s actually connected to the sender.
Snoots
Roger
Jimmy Sierra
350 w/203
Sigh.
chubhub6969
