Blue Ox
Turning Diesel Fuel Into Fun
- Mar 27, 2018
- LI-NY
- Derek
- MCMLXXXV
- K20HD
- 6.2L
If it was an issue, a friend of mine was a manager of a diesel shop.
He would put a steel liner in the advance of the aluminum case and problem solved at additional costs.
The problem with these is the weight retainer plastic retainer will disintegrate and look like black sand in the pump.
This plugs the return fitting on top of the pump.
If a Roosa Master cannot return fuel to the tank, it will not run.
You can remove the plugged fitting and it will again run.
There is a clear ball in that fitting that plugs with the black sand.
I have driven out that clear ball from a spare fitting and kept in my glove compartment, just in case.
You can use air to blow the sand out of the fitting but you need to push the ball off it's seat to get air to go both ways.
I usually just replaced that plastic retainer on the back of the weight retainer.
I comes in the gasket kit.
For my personal pickup, I went to the solid weight retainer and had the advance sleeved.
Most of the weight retainer remains in place, with the plastic retainer gone and works as it should but can wear on the pump case.
It usually gets replaced when the engine quits.
But a lot have ran for thousands of miles with the ball driven out of the return fitting.
I was just concerned that you were making out that rebuilding an injection pump is like rebuilding a fuel pump. When people start spouting off about how easy and cheap it is it's a disservice to the entire business. i.e. that's why I asked about the timing advance. Because unless they're sleeved they have about a 100K mile lifespan. And unless you use the reamers to check the wear and oversize the pistons they're going to run like cr@p. That might be why your experience of a degree or two of timing makes such a big difference. Not saying they shouldn't be timed properly but if the advance is shot they're going to be a pig.
BTW, running without a flex ring will beat the life out of the rivets on the weight cage. They not only shed metal into the pump, but will eventually break. When they break, the governor weights stop spinning and the governor thinks the engine is stopping. It's response will be to push the metering valve wide open. If the operator is quick on the key the solenoid will shut the engine down. If the operator isn't quick, or present, the engine's next destination is the moon.
