need help with lights
fishmaster
utah
marshal
k1500
wondering if i could get some help here. its an 1984 gmc k1500 high sierra and the reverse lights are stuck on. i can not find my owners manual to pull a fuse and i can't find a online version. does anyone know where the switch is so that i can look and see if its stuck? :shrug: help need fast.
MrMarty51
Eastern Montana
Martin
Standard transmission, the switch is on the transmission case.
Automatic transmission, the switch is on the steering column and also contains the neutral safety switch.
More information is needed totell You any more about it, except, the switch has a live wire going into the switch.
fishmaster
utah
marshal
k1500
thanks for the help :)
fishmaster
utah
marshal
k1500
yes i did, i rolled under and found the wires and had a buddy of mine look at it with me, we moved away some mud, unplugged them then plugged it back in now they work when i want them to.
fishmaster
utah
marshal
k1500
alright i got something really strange that happened. i crawled under again and found the wires cause the lights started to come back on so i just cut them, you'd think that the lights would just be off for good right? wrong! now they work when i put it in reverse. i don't know how, but i think i'm keeping it that way.
88V30
