Need a five speed transmission
Nick Spicer
Franklin
Nick
R3500
Hi, I have an 88 crew cab 350 auto. It is all original and I am looking to change the transmission to five speed. Does anyone have any suggestions for a good five speed that will match the stock 350?
2x4
Thanks!
Nick Spicer
Franklin
Nick
R3500
sorry I meant I need a good five speed automatic
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Im not sure on a 5 speed auto... other than an earlier generation allison transmission.
Typically theres the 4L and 6L units in GM stuff ?
RecklessWOT
New Hampshire
Kevin
V10 Suburban Silverado
Agreed. Most GM truck auto transmissions were 3 or 4 speed (if they had overdrive) till they jumped straight to 6 speed. I'm sure there was a 5 speed somewhere in the mix but can't think of one off the top of my head. Any specific reason why you're dead set on 5?
Vbb199
Salisbury NC
Vince
I believe the "cateye" generation 6.6L duramax trucks had a 5 speed allison.... whereas the next gen 07-10 had a 6 speed allison...
Only 5 speed i know of :shrug:
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
4l80e/4l85e Tough, low first gear, .70 over drive. use 411 or 866 stock ECM to control, or many aftermarket controllers, but $$$
Washington
The NAG1 in our old SRT is a 5 speed, but yeah there’s no GM gasser longitudinal 5 speed auto Im aware of.
OP needs to be more specific as to the request.
Washington
Yeah, not that it matters but 01-05 models were 5 speed Allison. 2006-2019 are 6 speed.
The 5-speed Allison was used behind the 8.1L HD trucks as well.
Nick Spicer
Franklin
Nick
R3500
It doesnt have to be a five speed I just wanted something more efficient something with over drive but will work with the stock set up or moderately modified
Vbb199
Salisbury NC
Vince
700r4 (4 speed) will bolt right up, all you need is a tv cable to maintain line pressure, and lockup controller.
Or
A 4L60e/4L80e from a mid 90's truck witha independent controller.
RecklessWOT
New Hampshire
Kevin
As ****** as it is performance-wise, the 700r4 was actually quite efficient for a 4spd. The OD was so tall on the highway you can get pretty good mileage. They just have no balls around town and aren't too too tolerant of heavy abuse. It's not electronic so there's nothing funky you'll need to do to get it to work on a stock setup, just bolt it up and go. For just a driver they're halfway decent
Vbb199
Salisbury NC
Vince
Aren't too tolerant of abuse in stock form**
Haha
1998_K1500_Sub
