- Jul 3, 2025
- Midwest
- Shawn
- C10
Hello all,
So here's the short term plan with our 81 C10 Custom Deluxe with a stock 250 and factory MY6 NP833 overdrive 4 speed. LS swap an '05 Gen 3 6.0 from a donor G3500 van and add a Tremec TKX 5 speed manual with the close ratio setup. We'll follow this with new driveshaft and a 9" housing with a helical traction device holding 3.50 gears.
This is an absolute bare bones truck with 0 options. It's going to be a cruiser with a/c and later cruise control. We've purchased mounts and a such through Tejas SteelWorks. The engine should be forward a few inches and will prevent notching of the frame rail on the passenger side and allow for the truck accessory drive and components to be used.
Here's my concern(s). Will the TKX fit in place of the MY6? Planning on SFI bell housing right away to add a Wuhan War Whistle later. I don't want to cut the high hump if possible. Also, will the mid shifter conversion be necessary if the power train is moved forward?
Any help or thoughts are greatly appreciated. Thank you in advance.
