Swims350
- Jul 30, 2010
- Logan WV
- Chris
- K10
- none
I know technically this should be in th eother vehicles, but I figured it's for brakes maybe get a better/faster answer in here.
As you know my brakes are giving me fits now, and I removed the ABS, on this truck is RWAL only, with a isolation/dump valve, that's removed, so it's like old school squarebody power brakes.
This is my problem...
I bleed either side, starting on the PS rear of course but either one does this same thing..
bleed them once, works good, twice, still good, 3rd time, 4th. time any after barely get anything coming out and the pedal inside the truck moves less and less. The first time we'll say it moves halfway down, that's it, maybe more, 2nd time it'll only move 1/4 or less, 3rd. 1/8 or none and etc.
ok so I try to bleed them up front, at the prop. valve or at the MC. So this is what happens, pump the pedal and hold, crack the front line loose at either the MC or the Prop valve, fluid comes out, pedal travels all the way to the floor as it should.
crack the rear line loose at either the MC or the prop valve and the pedal moves only an inch or less, and does the same crap, 1st try an inch, 2nd try 1/2 3rd try nothing.
now bleeding the front brakes at the calipers the pedal will go all the way to the floor as it should.
one last thing, when the MC cover is off and you hit the pedal gently and watch it, the rear most part(for the front brakes) shoots up a stream of fluid as it should, the front tank(for the rear brakes) does nothing, no stream comes up or anything.
I think the master cylinder (MC) is shot, what do you think?
