My 81 crew cab build
Driver4r
Nebraska
Trevor
k10,c20
Chuck
Grande prairie
Chuck
K30 crew cab
That's a cool idea ill have to look into it. I am doing the 63 swap right now ill post pics in a bit
Sent from my iPhone using Tapatalk - now Free
Driver4r
Nebraska
Trevor
k10,c20
People have even gone all the way up to 12 each side of the wheel.
Chuck
Grande prairie
Chuck
K30 crew cab
This is what 63s with factory front mount. Gonna try it out before I change anything else. Shackles are 10" right now.
Chuck
Grande prairie
Chuck
K30 crew cab
Scrapped the 6.2. for less I can build 400 hp 383 so that's on the plan now. Sold the 6.2 with arp studs and fly wheel for a good sum. Got the vortec block. 95-98 non vortec heads and torquer intake. Start the build in a few months after I install the cross over and and figure out the front springs.
Chuck
Grande prairie
Chuck
K30 crew cab
Also scrapped the 63s wasn't enough bang for my buck.
That's a great build. I'd like to see who the aftermarket compressor is powered and mounted.
Stewzer55
Ohio
Stew
R30
What kind of bed is that?
Sent from my SPH-L710 using Tapatalk
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
Do you have a plan for this truck, our are you just throwing whatever parts you come across at it? Cheaper, less work, and more fun if you're got a concrete plan and follow it.
:laughing1: You mean my method doesn't work??? I've had concrete plans for my projects, then come across a good deal on a parts truck, or find something super cheap like an A883 OD trans, or get a chance to pull Air Locker and Detroit Lockers , NP205, front and rear axles, off of some trucks on their way to the scrap yard then my concrete plans are out the window and plans change. :shrug:
Chuck
Grande prairie
Chuck
K30 crew cab
I get board and start inventing the wheel with other guys ideas. The bed is home made farm box special. Up in canada here we get no military surplus. I have decided to stick with 38s cause I run her on the road. The 383 should be a solid plan.
Chuck
Grande prairie
Chuck
K30 crew cab
I think I am gonna order the 8 inch easy ride tomorrow hopefully they are the right fit
Dammit. No Cookie for that guess then.
Chuck
Grande prairie
Chuck
K30 crew cab
I am going to be putting a regular box on at some point. Sorry no hero cookie for you
sammygunns
