My 350 shutting off while driving
Hugomartin
Banned
Nc
Hugo
V20 3/4 ton 5.7 350 suburban
I installed a new ignition starter switch now I’m having a time figuring out where the gear selecter tie goes
Hugomartin
Banned
Nc
Hugo
Socket sizes used 5/8 on steering column 5/16 and 10 mm on ignition switch took me all day u gotta keep Foward pressure wen installing new ignition switch , eliminate the play towards yourself by pushing foward then tighten bolts
Hugomartin
Banned
Nc
Hugo
Not sure how this tie is supposed to be hooked up . Without the tie hooked up the orange selector won’t move thanks
Hugomartin
Banned
Nc
Hugo
Ok guys I replaced the ignition starter switch .. so I went for my first test drive went down the highway then it died again as I’m slowing down at the stop light... so it’s gotta be a short from the starter to the battery possibly ? Luckily I managed to crank it back up
There is a tab on the column that moves when you move the shifter. I don't have a pic.
Short? I doubt it. An open, yes. I'll bet you're losing power to the distributor. Check your connections on the starter solenoid and dizzy. Inside the dizzy, check your connection to the pickup coil.
Hugomartin
Banned
Nc
Hugo
I fixed the shifter bro.... But it still died on me after 10 min after couple stop lights , luckily was able to get it going again... I wonder how difficult of a job to rip out the wires off the starter and get new ones but for the life of me i cant see where they travel to.
Battery hot travels to starter hot then....?
Have you tested the ignition coil. A coil will get hot and fail,then cool and start working again.next time it dies you need to immediately check for 12v at the distributor. If it dies and you have 12v there.we need to test the distributor components.
Hugomartin
Banned
Nc
Hugo
Hugomartin
Banned
Nc
Hugo
Ok just got the starter down and removed the shroud . Going to tighten nuts... I wonder how to test the wires ONLY for I suspect conduction may be intermittent on one or more of these wires.
Hugomartin
Banned
Nc
Hugo
Ok a chart
Hugomartin
Banned
Nc
Hugo
I’m thinking that I have an intermittent open circuit.
The chart I posted seems incorrect be cause battery hot terminal seems to go to the starter and the alternator hot terminal
That is correct. There also should be a wire going to the distribution block on the firewall.
Sorry didn't read close enough,you have tbi with a divorced coil you to check for spark and, 12v to the pink wire A.S.A.P after it dies. If it were mine this exactly how I would do it as soon as it died I spray carb cleaner down the tbi. And try to start it no start? We know it's probably not a fuel problem. I'd check for spark to the coil wire,no spark see if the coil has power coil has power,we've isolated the problem to the distributor or coil. No power to the coil we have a bad wire or switch. If you do the above we will be real close to knowing what's wrong.
Hugomartin
Banned
Nc
Hugo
I’m able to start it up after it dies
DamnTexan77
