My 1980 K20 with a Quadrajet left me stranded...help
roguewave
Texas Hill Country/South Portland, Maine
Bobert
76,83,84,87,87,88.
4X4
Did one of my fly,buy and drive hairbrain things, it’s very nice original truck with no rust.
I think it sat for a bit but ran fair when I left the sellers house to drive 1400 miles home. Got stuck in traffic right away on the 210 freeway in San Bernardino, Calif. After about 20 miles it started to not idle while in traffic, I did the neutral to drive thing to keep it going. After traffic let up I thought I’d be OK, got it running along at 60 mph and it started to bog down, felt like a fuel issue. I limped off the freeway to a gas station parking lot and tried to find the answer. Carb # is 17057204, I didn’t bring tools along this time except for a 4 in one screwdriver and a mini crescent wrench.
my question is...can I partially rebuild/clean it in the parking lot? Have not really rebuilt one before but willing to give it a shot. I’ll walk to Oreillys this morning first thing and try and get a kit for it and some tools. I did undo the fuel line and stuck it in a bottle and cranked it over, it seems to be pumping fine. Took off the inline fuel filter and tapped it on the ground but saw no trash in it.
thoughts ?
Full of high hopes before leaving LOL
AKguy
Alaska
Randy
K30 Crew Cab Silverado
I would install a rebuilt carb and drive it home.
roguewave
Bobert
76,83,84,87,87,88.
4X4
Just discovered the charcoal canister sent crap into the carb. Saw all these, what I thought were mouse turds, turned out to be charcoal hah! Hopefully on the road soon, we’ll see...
Thanks for the suggestions
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
I was just going to suggest inlet filter. But I guess it is either did it's job or didn't.
Good luck with the repair.
350 w/203
Hope you got it fixed and made it home ok.
Does it have a catalytic converter?
roguewave
Bobert
76,83,84,87,87,88.
4X4
Back on the road, made it to Blythe. I found a real cool guy within walking distance of the truck, go figure, he took carb off and rebuilt it this morning. It had all kinds of charcoal inside. Runs like a top now....so far. Slept ( not much) in the cold cab last night, I’m bailing early today. Zzzzzz
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
I have seen the charcoal canister clog up the float bowl before. It does occasionally happen, not sure how or why it happens. That vacuum line is designed to collect fuel vapors snd store them in the canister, so how does the charcoal chunks get sucked up into the carb? The float bowl isn’t under vacuum.
My thought would be the canister isn't being purged, due to a pinched vacuum line etc. So as tank pressure builds the charcoal is pushed under pressure not brought up by vacuum through the bowl vent.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
That makes sense. I suppose it wouldn’t take much pressure to move those tiny chunks.
Powerhouse Ranch
3G Connoisseur
PA
Luke
'80, '86, '88
C25, K5, V15
very nice truck! love the fly, buy and drive method, would love to do that one of these days
Salty Crusty
Gary
c1500
Good on you, great looking truck.
Nothing in the world wrong with a quadrajet and rebuilt correctly, it'll give you great fuel economy (for a carb in a truck with the aerodynamics of a wall) and last forever.
I flew from Lubbock TX to KC and drove an '85 Mercedes convertible home once in freezing weather after a blizzard. It was either that or miss the car and that wasn't going to happen. When you find the right one, you'll do whatever it takes to get it home including having the carb rebuilt :D
78C10BigTen
pennsylvannia
C10 BIG TEN
Thats some roadkill stuff there
mo4154
