Modern alternator on 86 C10
Creedux
Canada
Hey guys, im wondering if anyone here knows if a modern DR44 4 pin alternator can work on my 86 C10 that uses a 2 pin connector
MikeB
I can't answer your question, but here's a comment: The GM 10SI and 12SI alternators are probably some of the most reliable ever made. And they are a heck of a lot cheaper than the newer ones.
Here's good article on selecting one. The website may even have info on the newer models.
http://www.madelectrical.com/electricaltech/delcoremy.shtml
firebane
Calgary, AB
Curtis
They have pigtails that allow what you need to work. Just have to decide on the alternator size.
I put a CS144 in my old 74.
Creedux
Canada
Where do I find these pigtails?
Creedux
Canada
When it comes to electrical I'm completely lost ... electrical is my weak point and I absolutely hate it with the passion. If anyone here could help me out with how to properly wire a DR44 alternator in my 86 C10 it would be greatly appreciated !
firebane
Calgary, AB
Curtis
Napa carries both parts from what I found.
Echlin EC80 and Echlin EC82
EC80 doesn't have a restistor and the EC82 does have a resistor.
Creedux
Canada
Does it matter which one i go with ? Is one better then there other ?
firebane
Calgary, AB
Curtis
I put the one with the resistor on my truck.
Creedux
Canada
Just did a google image search and the 2 connector looks right but the 4 pin connector doesn't
Creedux
Canada
The 4 pin connector on my DR44 looks like this
firebane
Calgary, AB
Curtis
All newer alternators by GM use the pin plug. The older SI models used a 2 pin. If you look at the adapter you'll see its a 2 pin to 4 pin.
Creedux
Canada
I see the 4 pin connector but I don't think it's the right shape.
Here's a pic I found online of a DR44 plug on the back of the alternator. Hope im not making this frustrating :sorry:
The CS and DR use a different style connector. Whether or not the DR is compatible, I don't recall exactly. I think it is though, just wire in the correct two terminals.
Knightewulf
