Caster settings 1977 C10
Steppin Razor
Houston
S
C10 silverado
Camber wears out tires. Put it back like it was. Busy BBL
I know, but I'm not concerned about inside wear on the tires I've got. They aren't great, I don't mind if they wear a bit faster. I'm not going to put it back, I want positive caster.
Okay Home now, if they had 3/4 in the front 1/2 in the back . In a previous post I told you my crude questimate was put 5/16-3/8 in the front then shim all bolts equally to bring camber close. Sounds like it was 1/4 in the front then shimmed for camber. Put it back that way. Set toe with a tape measure 1/8 - 3/16 . IF the tires are straight up and down. ( Get an angle app for your phone,)check the level of the spot you are parked side for side. 0 the angle finder to the ground,check the angle of the wheel if it's close to straight up and down 0 to -.5 degrees run it until you can get it aligned.
samelthecamel19
