Mini starter engagement depth
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
Checking starter engagement on flex plate. It’s an oem type mini starter. Read on the inter webs you want about 60% engagement depth. I get full depth. The videos I’ve seen show adding shims behind the clocking ring of a clockable starter. Should I worry?
When my wife gets home, I was going to check my static timing with the fuel pump relay pulled and that includes cranking with the starter. It’ll be the first time cranking.
With the drive gear retracted, you want around 1/8th inch clearance between the shaft and the flexplate. If it's too tight, just use starter shims to get it where it needs to be.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
Fully retracted is around 1/8”...maybe 5/32”
It goes flush with the adjacent cutout part of the nose:
I mean 1/8" clearance at the tip of the flexplate teeth. The amount that the drive gear slides out really doesn't matter at all, so long as it engages a sufficient amount of the teeth, and it retracts far enough that it doesn't drag when the engine is running on it's own.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
I think I get what you’re saying. I keep finding videos of random mini starter/sbc combinations. I’m hoping since my starter is specifically for a 97ish l31-r equipped truck I’m hoping I’ll be pretty good to go.
It’s definitely good on the paper clip test.
The last few of those starters that I've installed on older blocks didn't need any shims either.
jash1990
