Messin' with a 305...Camshaft
Ronno6
South Mississippi
Ron
I am still contemplating livening up my 305.
Truck is an 84 C10, but engine is a 1-piece rear seal 305, so, unsure of year.
Odd serial # almost makes me suspect it is a crate motor.
Tranny is Muncie M20
Rear 3.73 posi.
I have Hedman 1 5/8" long tube headers and 2 1/4" dual exhaust with Walker Thrush mufflers.
Heads will be either 601's or 416's stock 1.84" / 1.5" valves and maybe some mild porting/polishing work.
Intake TBA, probably a dual plane
Carb Holley 600cfm.
Now I seek input as to cam selection.
As I have vacuum brakes, I need to maintain good vacuum.
Other than that, it will be a daily driver, so not too crazy.
But, I'd like it to go..........
Hydraulic flat tappet lifters.
Summit has a bunch of kits, but I need guidance on specs.
SquareRoot
A lot of "will be's" in your post. That means you haven't went down the rabbit hole yet. Toss the 305 and buy a crate 350.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Above ^^^
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
In all fairness, the setup you’re looking it is as good as it gets for a 305. Go 1.94/1.5 on the valves and you’re there. A good mild cam would be a Comp 12-300-4. Anyway, I think you could make 300 hp if you play your cards right with this, but otherwise I would suggest getting a 350.
Ronno6
South Mississippi
Ron
I have not purchased the heads,cam,or intake.
I have 601 heads available for $50.00/pr and 416's for $100.00 both probably needing valve jobs.
I KNOW that moving up to a 350 would be the way to go........but I am following the old adage "work with what you have."
Much $$$$ to be spent on body,paint and interior.
I'm just trying to give the pedal on the right a bit more *****..........
p.s. 300 HP would be fine!
idahovette
Firefighter
Weiser Idaho
Perry
K20-K10
I personally would stay away from "company grind" cams. (Summit, Jegs etc.) I prefer Comp Cams because I have had very good luck with them. I think 73c20Jim said it first? YMMV
Ronno6
South Mississippi
Ron
Thanks!
Isn't that cam a bit on the mild side?
What are its advantages/disadvantages?
I wouldn't mind going a bit hairier.......
DirtyDYT
Ohio
‘79
Thanks!
A mild cam is totally appropriate for a truck because you’re looking to maximize torque across a broad swath of RPM for drivability. A lopier cam would probably perform a bit worse than what you have now until it’s up to 4-5k. I can’t imagine driving my truck like I do my Honda.
BIG BLOCK it!:cheers:
Agreed 100%. I’m wrapping up my own roadkill-esque 454 swap C10. Truck, engine, and parts ran me $2000.
And....OFF the deep end we go..........
Can we? Please? :D
MikeB
I have to disagree with the statement above about Summit cams. Their old school grinds are easy on valve trains and will work fine for a long time. Gotta be tens of thousands of the popular K1102 204/214 cams kits out there.
For your combo, how about the SUM-K00032 cam and kit -- 204/204, .427"/.427". It's part of a cam line Summit started selling several years ago. I suspect they are made by Crane because the specs are identical to the Crane Energizer cams. In fact, Crane has a 10032 cam & kit for $60 more. (Note the P/N similarity.) Not sure what the difference is, but could be Crane's lifters are better.
Of course the SUM-K1101 at (194/204, 398"/.421") would get the intake valve closed a little earlier on the compression stroke for decent cylinder pressure in a low compression engine. It looks to be a close copy of the cam used in lots of 307-327 engines in the 60s-70s.
Finally, the 305HO engine that was used in the Z28 had a "relatively" hot cam that you might want to research. That engine also used a decent set of heads, but you know more about 305 heads than I do. Food for thought.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Friends don't let friends do 305s...
Ronno6
South Mississippi
Ron
Thanks.
Definitely food for thought.
As for heads, both sets which I am considering were 305HO heads.
Both have 1.84" intake and 1.50" exhaust
the 601's have a slightly smaller chamber to boost compression ratio to about 9.6; the
416 would yield about 9.0 but I am not sure which pistons that would require, nor which pistons I have., as I am unsure as to exactly what my motor is......I have been unable to get the block casting #, and the serial number (K0190560) is not indicative of it being the original motor. It has the 1 piece rear main seal, but perimeter bolted valve covers.
I am looking around at 350's and seek guidance on those, but I will start another thread if I cannot find anything out thru a search of the forum.
Ronno6
South Mississippi
Ron
Saved a few bucks....pulled a rocker cover and found that my engine already has the 416 heads.
That "just" leaves cam and intake (along with head work....)
Malo83
