LS Square Bodies?
johnmc
mass
john
k 10
305 tuneport injected
where is the pics? I need to see your motor mounts in detail please.
4000+ stalls are very daily driveable on 60e and 80e trucks
Provided you keep the lock up feature, and the converter gets a break to cool the fluid. Hi Stalls create heat, and 4K will create mega heat for a short lived trans as a DD. With lock up, the fluid will cool since there is no slippage.
Joshua8336
Dirty South AL
Joshua
all i plan on doing for mounts is using fbody clamshells, $50 from Rockauto, and Spohn's 1 inch set back's. $80.00 give or take, i'm gunna mock up the engine like i like and weld the spohn piece's to the truck motor mount supports
johnmc
mass
john
k 10
does the clam shell bolt to the block? and do you have a link for the Spohn's 1 inch set back's?
Joshua8336
Dirty South AL
Joshua
no problem, which fuel pump are you going to use?
johnmc
mass
john
k 10
I have the high psi tuneport fuel injection pump in the tank . I hope i can use that.
I am still on the fence if i want to go with the gm carb intake and a 850 cfm carb,cam swap,valve springs,l92 heads to make 550 hp7,500 rpms .or 6.0 l92 heads ,cam and valve springs and deal with reprograming is not my thing.
Joshua8336
Dirty South AL
Joshua
get some pics up! get all of your mods on then take it and have someone tune it, don't change the parts on it and you won't have to tune it again for a long time
Manbearpig
Midland, Tx
Tyler
1500HD Quadrasteer
Unless you're running a huge cooler :crazy:
It better be a cooler about the size of your AC condensor. 4L60-E's already need added cooling. NOt saying it can't be done. Just saying for a DD, I'd sure see about keeping the lock up feature.
Joshua8336
Dirty South AL
Joshua
got the 4L60E yesterday. now i'm fixing to start pulling back out the 4.8 and POR15 the front frame and k member, will get pics when i can
Manbearpig
Midland, Tx
Tyler
1500HD Quadrasteer
As an eBay Associate we earn from qualifying purchases.
True, those type work better so it doesn't have to be so big. Those are better than the bigger tube aluminum fin type. That type is alot like a radiator itself. Normally with lower gear, you can get lock up about 40-45 mph, but in an E trans I'm sure it can be adjusted highter with ECM tuning.
juicedimpss
Racine
Hank
k20
bump old thread with a few pics
84 K20 5.3/sm465
Dennis Blom
