LS bellhousing stiffener rods
Blazerbiker
Rifle CO
Stephen
K5, actually a Jimmy since it's a GMC
504in
What everyone is missing here is that all the later model drivetrain pieces that did not have side braces came in IFS trucks that don't have plunging driveshafts. The strut rod is there to keep driveshaft plunge forces from working on the adapter and the back of the transmission. It's not a bellhousing brace. It is nice that the later trans housings and adapters are generally beefier than earlier stuff but if you end up with a sticky front driveshaft on a leaf spring suspension, something is going to move and with a side brace, at least the trans tail will live for a little while. That side brace is a good idea.
Don't confuse this will the side brace going to the frame rail. It served that same purpose but also was a problem with frame flex and motor mount wear. Those side braces are a bad idea.
Camar068
Air Force Supporting Member
Kentucky
10 yrs Air Force
before I did my swap, they were there but not hooked up. With that I deleted since they didn't fit anyway. I used the 5.3/4l60e/adapter out of a 2006. No issues, but I'm not lifted more than stock.
K5Rob
Maine
Rob
K5 Blazer
#1 The strut rod is there to keep driveshaft plunge forces from working on the adapter and the back of the transmission. It's not a bellhousing brace. It is nice that the later trans housings and adapters are generally beefier than earlier stuff but if you end up with a sticky front driveshaft on a leaf spring suspension, something is going to move and with a side brace, at least the trans tail will live for a little while. That side brace is a good idea.
#2 Don't confuse this will the side brace going to the frame rail. It served that same purpose but also was a problem with frame flex and motor mount wear. Those side braces are a bad idea.
So side brace #1, or strut rod as you called it, is the long one from bell housing to the tcase (good idea)
And side brace #2, going to frame rail, would be the two rods going from bell housing to motor mount plate (bad idea)
Am I reading you correctly?
Hunter79764
Grand Prairie, TX
Suburban V20
My very limited experience is that I opted not to reinstall that bar from the bellhousing to T-case, and shortly thereafter cracked the adapter between the T-case and transmission. There were other factors involved for sure, but I hate thinking that my decision not to find another bolt (the reason I didn't re-install it) might have been the deciding factor that cracked the adapter housing. I'd put it back if you can.
Generally speaking, OEM's don't do things like that for no reason. And the newer stuff with no brace is all IFS, as pointed out above, and that can definitely make a difference in how the load is applied.
And this is exactly the kind of info I don't have experience with. Thanks for that
1lejohn
texas
john
k-1500, 2500 HD
I don't run the bars going from the motor mounts to the bell housing. I deleted mine because when we pulled the old motor the kids had one job mark the mounts pass and driver, up and down. They failed. When we stabbed the motor the bars where wrong. I cut them off! I swapped the 700R for a 350 and don't have the cast bell housing half that has the bolt holes for the rods. So oh well. I don't really wheel the truck anyhow. I would like to have kept the 700 housing. Another fail.
K5Rob
Maine
Rob
K5 Blazer
Thanks for sharing. So no issues to report?
1lejohn
texas
john
k-1500, 2500 HD
No I haven't run into any issues driving the truck. I daily drive it to work over some horrible roads here on the SE side of Houston.
Blazerbiker
Rifle CO
Stephen
504in
That is correct, sort of. You put 2 separate things in #2. The side brace to the frame rail is essentially an angle iron with a couple of bushings that bolts to the side of the T-case and the bushings attach it to the frame rail. These were in the earlier 70s trucks and were a bad idea.
The rods from the motor mounts to the torque convertor cover don't hurt anything but real world use indicates that the bellhousings don't break often at all and those rods are generally lost or don't fit with changes. If you have them, it doesn't hurt to keep them. If you don't have them, I wouldn't (and don't) spend any time putting them on.
K5Rob
Maine
Rob
K5 Blazer
Thanks for clearing that up. I wasnt aware of the side brace.
GATruck85
GA
alan
k20
If anyone happens to have the two brackets/spacers that go between the clamshell on the engine block for the Bell housing support rods. I’m looking for one.
Skippy
