Lowering help
New_Guy
colorado
Shane
This will sound slightly idiotic, but I need some advice. I want to lower my truck, I was thinking about 4-5ish.... But my concern is how low can I go (on a budget so bags are out of the question) before I cant haul my motorcycle to the track? What I mean by that is; hitting the bump stops or bottoming out on the smallest of bumps.
Sent from my HTC 10 using Tapatalk
bluex
Spartanburg SC
C15
If you do 4" rear with shackles an hangers you'll be fine. If you do a flip kit you'd need a notch depending on the weight of the bike.
New_Guy
colorado
Shane
The bike only weighs 410 lbs
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
3 inch front 5 inch back. Spindles (2inch) or a drop coil, or cut a coil off factory if on a tight budget. In the back, new hangers, drop shackle combo. If you go with a flip kit ...its closer to 6 inches if memory serves me correctly.
86Peter454
Missouri
C10 Scottsdale
i plan to drop mine 5 inches in the back.
i got this rear flip kit because it comes with shock extentions and i plan to use my stock ones atleast for a while.
http://djmsuspension.com/product/fk1024-5/
then ill be getting this notch kit. for your situation id say a notch is a must.
https://www.suspensionshop.com/chevrolet-c-10-1973-1987-rear-frame-c-notch-part-33152/
then ill be doing 2.5 drop spindels
https://www.suspensionshop.com/chev...2-5-drop-spindles-mcgaughys-part-33153-33154/
and also shock re locators for the front again plan to reuse stock ones for a while.
https://westernchassisinc.com/1973-...ount-Relocation-Kit-for-Lowered-Trucks-Front/
(you can get these a tad cheaper on ebay.)
i suggest the shock re locators if using stock shocks just will give them a bit more travel to keep from bottoming out.
then gonna cut front spring to drop it about another inch to inch and a half.
about the cheapest set up i could find. some things may need replaced later like the shocks and possibly front springs but to get started with the look on a budget should work out well enough.
smoothandlow84
Steve
Always a good idea to replace the ball joints and tierods since your gonna be tearing apart the front end anyways.......
And of course a front end alignment.
Todd Lemon
