Looking to sound deaden your truck? Dynamat? watch this first.
Nasty-LSX
TogetherforeverCovid19
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
I have been doing sound deadening for years. I can call myself a expert installer. I have tried them all. Yes I have. More and more times customers
want me to install DYNAMAT $$$$$$. I used to be a DYNAMAT die hard believer.
If you want the truth watch my video. I do not get paid nor have a sponsor
for any type of product. If you skip on the video, then you are skipping good information. If you care what you want to spend your money on listen to it'all.
Please like and comment as it helps to circulate my videos. Thanks
FranticMeeping
Minnesota
6.2 Diesel
Thanks for the informative video! I was looking for some sound deadening for a tractor I’m resto-modding, and this fits the bill.
82sbshortbed
Why like that?
SE Texas
Doug
1500 shortbed, 1500 longbed
Good info. Thanks
yevgenievich
Place
Name
Year
Model
Size
If you would like to give me a call PM me your #
Had a chance to play video eventually. Turned out same to what I ended up using. I also had good luck with closed cell foam backed with mat type material for certain applications
Doppleganger
OH-MI: Just like it sounds
Just got my crimper, now this. Looks like a plan.
Teacher says, every time a bell rings, an angel gets his wings. And every time Nasty makes a video, Dopple's wallet gets lighter.
:hat:
Wonder what Noico red's like? Pretty thick stuff.
da_raabi
Trailer Park Supervisor
FloriDUH
Adam
c30
Noico is decent stuff. I've used their butyl products on both the truck and my Camaro. In fact, I just got some more for a door job on the Camaro.
Keep in mind mass-adding materials like this are only needed sparingly. Dynamat etc always show full-coverage applications, but it's really not necessary. Sounddeadenershowdown did a lot of science on this and found that selective use of mat material for deadening "hollow" panels that echo etc is better, uses less material, and adds less weight to the car. See my pic below of what I did on the door. Closed cell foam is useful as a gasket layer, but is not necessarily insulating on its own. The true key to sound deadening is MLV, or mass loaded vinyl. So you selectively layer the butyl/foil material directly on the sheetmetal (only where needed), full coverage with the closed cell foam gasket layer, then full coverage with MLV. I also chose to use mass-backed carpet in the truck. I've got a thread around here somewhere on the job... It works very well. Believe me!
Now, full coverage with the butyl/foil is useful for heat blocking. But again, no need to cover the whole floor for that. I did on the truck, and it was a huge waste. Focus on those areas that need it!
Scott91370
Burleson, Tx
Scott
Sierra1500
I'm sure it would work but might be kind of expensive unless you had it already. I used a piece of roofing felt/paper for my tank isolating straps. Swung by a house under construction and found some in the trash bin and took it.
Nasty-LSX
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
:hat:
HAHAHAHAHAHAHAAHLOLOLOLOLOLOLOLOLOOL.. LOVE IT:dogpile::big_banana_Dance:
Doppleganger
I actually have a set of the original GM stuff. Got it on clearance from a seller on feebay maybe 18 months ago for a song. Just figured this stuff might work better.
Scrambler-Cafe
