Looking for no bs, tested, quality vacuum caps..
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
Maybe these? Says high quality rubber. Maybe put some Vaseline on them to keep them soft and not Crack? They have other types too.
https://www.amazon.com/dp/B08YZ55JT...abc_FPMY2Z5S3S2NMRNZAQTF?_encoding=UTF8&psc=1
Those ones look just like the rest of em lol. I did an internet search already, and they all looked like the same thing. Was checking to see if anyone here knew of a quality set. The Vaseline may help, but I think it's the extreme cold and heat fluctuations.
Camar068
10 yrs Air Force
sorry but as cheap as a kit is, keep it in the vehicle and roll. Every time you pop the hood, take a minute to check for vacuum leaks with starter fluid.
73c20jim
Tombstone, AZ
Ethanol in the fuel is probably not helping either.
Put ball bearing in cap then install. No fumes to rubber parts.
Camar068
10 yrs Air Force
Always used rubber hose with a screw plugged in the end.Never had anyone be concerned over it.
yeh thought about that after I posted. If you've got 2 the same size and don't want to run plugs, run a hose from one to the other.
59840Surfer
Montana
Joe
You may not go able to do that if they are different vacuum signals.
If one is ported and the other is manifold - or vice versa - you can create problems by sucking raw gas into the baseplate of the carb without controlling the mixture.
PrairieDrifter
North Dakota
Mason
This was my thought, just shove a ball bearing in the hose instead to look a little more clean.
I try to keep my farming genes out of my builds lol. No bailing wire, no scotch locks or wire nuts either lol.
PrairieDrifter
North Dakota
Mason
I just want something to last, I don't want to carry around vacuum caps or worry about having vacuum leaks and having to pull the air cleaner lid off. There's a lot of checks we should be doing, vacuum caps being crap shouldn't have to be one of them lol
Turbo4whl
Downingtown, PA
Wayne
We have a box assortment of scotch locks at work. Someone took a paint pen and wrote on the box, "Just say no"
idahovette
Weiser Idaho
Perry
K20-K10
....no....Wood screws????
Turbo4whl
Downingtown, PA
Wayne
@PrairieDrifter
I have no help for you. Some the caps and vacuum hose we get at work.. junk
Can you say imported?
PrairieDrifter
North Dakota
Mason
I absolutely would be that guy lol.
Camar068
10 yrs Air Force
True that, just winged that one....blocked is blocked I figured.
PrairieDrifter
North Dakota
Mason
I'm not knocking it, because I know it works, and I definitely wouldn't talk crap to anyone about it because I've done it too lol. Farmers like to use bolts though haha
PrairieDrifter
North Dakota
Mason
@PrairieDrifter
I've had good luck with gates stuff, I might even source some fuel line.
Nobody can win anymore.
johnalen76
