look what i found today!
Bman
Oliver springs,tn
Ben
GMC sierra classic 1500
5.0/ 305 LE9
In the famous words
"Well theres your problem" -Mythbusters
So i started off I knew the timing on my engine was off quite badly. just gonna check the timing of my engine. so i got the light and went to it. Well timing is right at 4 Degrees BTDC like its supposed to be. And i think...Hmmm I pull the distributor cap and Taa Da! Boy arent those puurrtty.
then i went and got me a Accel performance Distributor cap and button kit.
Oh boy dont she run a whole world better!!
And on a side note. My truck used to diesel sometimes when its cut off. and i believe i found a new reason to cause this. The little metal peice thats part of the three pins that the connector hooks to and and also ground to the coil to kill fire was rusted up. i believe mine dieseled because of this not making a good ground on occasion to kill the coil.
Bman
Oliver springs,tn
Ben
5.0/ 305 LE9
Any ideas what caused that to happen? i worried it could again.
Bman
Oliver springs,tn
Ben
5.0/ 305 LE9
I already put new cap and button and all that in.
350runner
tx
Ceasar
And they look like that?
350runner
tx
Ceasar
That shows you have have high resistance at either the wires or plugs. That's what would do it
Bman
Oliver springs,tn
Ben
5.0/ 305 LE9
thats the old cap and rotor. i put a new set on. runs great. im gonna do plugs and wires next
350runner
tx
Ceasar
Ooh ok lol
350runner
tx
Ceasar
Yea high resistance outside of the cap will do it.
highdesertrange
kalifornia
mike
k30
in my opinion that was el cheapo cap and rotor, not the greatest tolerances. for the contact to be bent like that I would say it made contact with the cap. you replace with a quality set so you should be ok. unless your distributor is worn out allowing the shaft to jump up and down. did you check for this? highdesertranger
skymagu
