long bed mod
Raider L
Shreveport, LA
William
What do you think about putting in a wood floor like the step side trucks have got, but in my long bed fleet side truck? Order two sets of the rails that are between the boards, weld them together and grind the welds down and polish the joints to look like they're one piece?
Then either contact the companies that make the restore kits for the step side trucks and ask them if they would cut the wood to fit my long bed, or just go over to Lowe's and get the oak planks and take them somewhere and have them milled to fit the rails?
I don't know if the cross members are the same width, if so attach them however many would be needed to the side of the cut out bed floor of my truck. Cut the floor out leaving the side edges where the fenders, wheel wells, and end plate up front bolts up, maybe weld in a stiffener along those edges to give them some strength.
Then take the wood and stain it, spray on the polyurethane, put in the rails, screw everything down. I don't know what the end looks like back there at the end of the bed floor where the tailgate is, but do whatever is needed to close that off and there you go.
What do ya'll think of my idea?
Raider L
Shreveport, LA
William
@Goldie Driver, @SDJunkMan,
Thank you guys so much for the info. I was reading one of my old car mags last night and in a '95 issue of "Custom Classic Trucks" in the back there was an ad for Mar-K and that's when I got the idea of putting in a wood floor. "I bet that would look cool.", I said to myself.
Goldie, I'm going to run down and pick up a couple of those old trucks, ha, ha.
I sent an email to Mar-K and see what response they send back.
Raider L
Shreveport, LA
William
@SDJunkMan,
Yeah, the ad for Mar-K is for a long bed fleet side! Hell, I wouldn't have to do a thing but put it in...well you know what I mean.
Yeah, it would be a hell of a lot of work wouldn't it. But if I already had the wood all there would be left to do is cut my bed out, reinforce the edges, put in some more cross members, and drill holes,(it sounds like a lot of work already), and then paint the wood and put it in, (sounds like a hell of a lot of work, ha, ha).
45tt
Florida
MJ
GMC Sierra Grande K15
Both my 67 C20 and 72 Custom Camper long beds had wood floors. I’m not sure how different the setup/measurements are between the years, but I bet with a little fab work it can be modified for your application. That’s if you have exhausted all other options for wood floor parts for your year of truck.
Powerhouse Ranch
3G Connoisseur
PA
Luke
'80, '86, '88
C25, K5, V15
In the '73-'80-ish years, there was actually an option for a long bed fleetside with wood floor. It used specific bed crossmembers and wheel housings. It was also uncommon.
are there any pics of this?
Moderator
Powerhouse Ranch
3G Connoisseur
PA
Luke
'80, '86, '88
C25, K5, V15
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
The wooden bed deck will not be as loud as metal, ..... when you get a load of gravel dumped in.
You also have the advantage of screwing in hooks or eyes for securing loads.
Termite_Delight
Lanark Ontario Canada
K2500
5.3 L33, 4l80e, NP241c
This pic was from a 1975 dually Camper Special I missed out on buying a few yrs back.
I believe Yellow Pine was used for the deck & not Oak...
Moderator
That was in real nice shape for being original. Too bad you missed out on it.
Jeremy89
