Little wire cut from bulk head what did it go to? Looks to have white stripe with it but can’t tell other color?
wildone454
wv
cody
Jgonick
West Texas
Joel
probably pink/white (PNK/WHT-350) runs to oil pressure switch (not oil pressure sender) which controls choke.
Wiring diagram LINK
wildone454
wv
cody
That’s what I was think it deff has the white stripe but coudnt tell the color and the diagrams I have seen can’t tell if it’s in the right pin location for it but that does explain why I can’t find it so I could could connect and run it over to new pressure switch
wildone454
wv
cody
wildone454
wv
cody
Dis gram shows this as brk pressure wring switch what do I need to order so it plugs in correctly
wildone454
wv
cody
When the tan pink/white and dr blue comes out of bulk head should they run across where wall toward motor or will they run to radiation and around that way
wildone454
wv
cody
Update found them they was all cut very close to the bulkhead they was hard to see can I take it apart and add new wires from inside out of the connector or will I have to just connect the short pieces
Old Guy Bill
KY
Bill
These are the type of terminals that were used in the ‘70s fuse boxes, they available from several places.
I’m not certain if yours uses the same.
wildone454
wv
cody
Check out new boyz squarebody rescue I was able to get in contact with them and they had each complete wire I needed. All I got to do now is put them in super great customer service as well
