Lift size?
DAbrams02
Daniel
Looking for a little guidance on what size lift my truck has, I just got it this past weekend. She's sitting on 33x12.5 15s. Thanks.
Skweegle89
Oklahoma
That's a 4" if those are 33s. I assume that's a suspension lift and not a body lift?
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
See if you can read any brand name and/or numbers on your front springs, if not, if you have lift blocks on your rear springs, those are usually good indicators of lift hight. My truck once had a Rancho 2 1/2" lift with 33" tires.
MadOgre
NA
NA
NA
NA
NA
I dunno. I would say 2.5" with 3" in the back. doesn't look nearly lifted enough to be 4" if those are 33s
A 4" definitely has the look of a lift.
Measure directly over the rear axle from the bottom of the frame to the top of the axle tube and I will tell you how much lift you have.
firebane
Calgary, AB
Curtis
I say we need more pics of said truck.. Looks nice from afar..
77 K20
Montana
K20 5" lift
HT383 fuel injected
I'd say it is around a 2.5" lift. I've had 2 trucks with a 4" lift and 33" tires and could cram my head in above the tire and look around. I don't think I could with that.
pgreensoup
