Lift options and recommendations for a 1980 Jimmy
Zelph
Nevada
Link it. Have all the flex and a better ride than any leaf spring could provide.
Russtypickle
Vancouver Island
Russell
Blazer
Not sure if everyone will agree here but I have a 6" lift in my '85 (IBPO) and I hated the way it looked. Although it rode level it always looked like the front end was
higher because of the height difference between the body line and wheel arches. I took it to a local spring shop and had the front lowered about 2" and moved the axle forward a little. Looks way better in my opinion not to mention it softened the ride as the lift put my front rear shackles at an angle that wouldn't let them flex. I run 35's on it and they do rub at full lock so I might get the axle moved forward a little in the new year as its really not that bad for most daily driving. I don't wheel it.
Auburn, Washington
How much is the axle moved forward. It’s not even noticeable.
I need to do that as well. Even w 5” of lift it is tight with the 35s and wheel offset. Just haven’t but I slapped in zero rates to get it up a little.
Once I move the sway bar and get the driveshaft lengthened I can shift it forward.
Shorty81
Baby Boomer
North West ohio
Darren
That looks way better. A little rake is the best look in my book.
K5 Blazer
Sant Cruz, CA
Holden
K5 Blazer
6.0L LS
Thanks for the info, my Blazer sits lower in the rear after a 4" lift. I would like to level it out or have slight rake in the front.
Rare Breed
