Lets see your gauge cluster setups
WranglerTJForum
Gillette, WY
I'm considering either the Dakota Digital or Classic Instruments gauge cluster for my 1973 K10 Cheyenne.
I'm open to other options as well. Just curious to see photos of those who have installed different gauges in their C10 / K10 trucks.
Lets see what you've got!
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
WranglerTJForum
Gillette, WY
I like that! Is that the Dakota Digital? If so, how difficult was it to install? Did you have to install new sending units or did it use the existing ones?
nvrenuf
Mobile, Al.
@WranglerTJForum it seems obvious, but I've got to ask - is WranglerTJForum yours? I'm a member there also (user = "John S") but not active because my wife doesn't want me to make anymore changes to her Jeep. :banghead: :Big Laugh:
WranglerTJForum
Gillette, WY
Yep, I'm the admin over at Wrangler TJ Forum ;)
I'm also a big Chevy square body fan.
WranglerTJForum
Gillette, WY
i did Dakota Digital vhx with New Vintage snap adapt so I don't have to cut original harness
I dig it! So this was plug-and-play with the snap adapter? You were able to utilize all your factory gauge sending units and what not?
dd1990
Oxnard, CA
Suburban 1500
Basically plug and play, but I used the dakota digital sending units for temp and oil, ran cable to coil for tach. I have a 90 burb so I was lucky the speedometer was already electric and just ran VSS signal wire to speed port on dakota digital
WranglerTJForum
Gillette, WY
Okay, so a pretty easy install more-or-less.
I've been looking at the Dakota Digital units. This may be the way to go. It's either this or Classic Instruments.
WranglerTJForum
Gillette, WY
I have to admit, those Dakota Digital GRFX gauges are tempting!
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
Dakota vhx's. Super easy install. Plug and play their senders, then a couple things like high beam indicator and 4wd indicator have to be wired in.
Use wire ferrules and crimpers to do a clean and easy job of wiring the brain box.
Mike Gresham
I chose to leave the OEM instrumentation of my M1028 CUCV stock with the idiot lights and instead designed, fabricated, & installed a custom gauge panel.
wonone
